Saltar al contenido principal
Asus Q551L Repair Optical Drive Replacement
Qué necesitas
  1. Asus Q551L Repair Optical Drive Replacement, Back Panel: paso 1, imagen 1 de 2 Asus Q551L Repair Optical Drive Replacement, Back Panel: paso 1, imagen 2 de 2
    • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
  2. Asus Q551L Repair Optical Drive Replacement: paso 2, imagen 1 de 1
    • Use the plastic opening tool to pry the back panel off the base of the laptop.
  3. Asus Q551L Repair Optical Drive Replacement, Optical Drive: paso 3, imagen 1 de 3 Asus Q551L Repair Optical Drive Replacement, Optical Drive: paso 3, imagen 2 de 3 Asus Q551L Repair Optical Drive Replacement, Optical Drive: paso 3, imagen 3 de 3
    • Lift up the sticker that sticks between the motherboard and the optical drive. Then, unscrew the one screw where it is marked and slide it out gently.
    • Watch out for the wires around the optical drive.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 647
