Saltar al contenido principal
Asus Q551L Repair Motherboard Replacement
Qué necesitas
  1. Asus Q551L Repair Motherboard Replacement, Back Panel: paso 1, imagen 1 de 2 Asus Q551L Repair Motherboard Replacement, Back Panel: paso 1, imagen 2 de 2
    • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
  2. Asus Q551L Repair Motherboard Replacement: paso 2, imagen 1 de 1
    • Use the plastic opening tool to pry the back panel off the base of the laptop.
  3. Asus Q551L Repair Motherboard Replacement, Battery: paso 3, imagen 1 de 2 Asus Q551L Repair Motherboard Replacement, Battery: paso 3, imagen 2 de 2
    • Unscrew the four screws to remove the battery.
  4. Asus Q551L Repair Motherboard Replacement: paso 4, imagen 1 de 2 Asus Q551L Repair Motherboard Replacement: paso 4, imagen 2 de 2
    • Un-clip both wire clips on the upper and right side of the battery.
    • Lift the battery out of the device.
  5. Asus Q551L Repair Motherboard Replacement, Optical Drive: paso 5, imagen 1 de 3 Asus Q551L Repair Motherboard Replacement, Optical Drive: paso 5, imagen 2 de 3 Asus Q551L Repair Motherboard Replacement, Optical Drive: paso 5, imagen 3 de 3
    • Lift up the sticker that sticks between the motherboard and the optical drive. Then, unscrew the one screw where it is marked and slide it out gently.
    • Watch out for the wires around the optical drive.
  6. Asus Q551L Repair Motherboard Replacement, Motherboard: paso 6, imagen 1 de 3 Asus Q551L Repair Motherboard Replacement, Motherboard: paso 6, imagen 2 de 3 Asus Q551L Repair Motherboard Replacement, Motherboard: paso 6, imagen 3 de 3
    • Remove the fan by unscrewing the nine screws shown in the images.
    • The four colored wire and the black cable need to be pulled out gently.
    • There will be wires around the fan. Make sure they are not stuck to it.
    • You want to keep the fan if it still in good conditions.
  7. Asus Q551L Repair Motherboard Replacement: paso 7, imagen 1 de 2 Asus Q551L Repair Motherboard Replacement: paso 7, imagen 2 de 2
    • Unscrew the seven screws Phillips Head 0.0793 MM on the edges of the motherboard.
  8. Asus Q551L Repair Motherboard Replacement: paso 8, imagen 1 de 3 Asus Q551L Repair Motherboard Replacement: paso 8, imagen 2 de 3 Asus Q551L Repair Motherboard Replacement: paso 8, imagen 3 de 3
    • Disconnect any cables that hold the motherboard.
    • Open up the white adjustable latch first to pull out the tapes.
Conclusión
2 personas más completaron esta guía.
Un comentario
Thanks for posting this guide. Helped me to fix this model computer for a friend. Very well done!
Robert Valentino - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 2,371
