Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
This guide will describe how to remove the battery on the Asus Q551L. This is a fairly simple procedure that requires only a screwdriver. The battery may need to be replaced if it cannot hold a charge, experiences heating issues, or simply ceases to function. Make sure your device is turned off and unplugged before removing the battery.
Partes
No se especificaron partes.
  1. Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 ,  two of them are 0.0793 JIS #0. Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 ,  two of them are 0.0793 JIS #0.
    • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
  2. Use the plastic opening tool to pry the back panel off the base of the laptop.
    • Use the plastic opening tool to pry the back panel off the base of the laptop.
  3. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  4. Unscrew the four screws to remove the battery. Unscrew the four screws to remove the battery.
    • Unscrew the four screws to remove the battery.
  5. Un-clip both wire clips on the upper and right side of the battery. Lift the battery out of the device.
    • Un-clip both wire clips on the upper and right side of the battery.
    • Lift the battery out of the device.
Conclusión
3 personas más completaron esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 42
Ultimos 30 días: 149
Todo El Tiempo: 3,940
