Saltar al contenido principal
Asus Q550LF-BBI7T07 Disc Drive Replacement
Qué necesitas
  1. Asus Q550LF-BBI7T07 Disc Drive Replacement, Battery: paso 1, imagen 1 de 2 Asus Q550LF-BBI7T07 Disc Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
  2. Asus Q550LF-BBI7T07 Disc Drive Replacement: paso 2, imagen 1 de 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: paso 2, imagen 2 de 2
    • Use an opening tool to pry open the rear cover. Lift the cover off and away from the board.
  3. Asus Q550LF-BBI7T07 Disc Drive Replacement: paso 3, imagen 1 de 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: paso 3, imagen 2 de 2
    • Use a Phillips #0 screwdriver head to remove the three black 7mm Phillips head screws that hold the battery in place.
  4. Asus Q550LF-BBI7T07 Disc Drive Replacement: paso 4, imagen 1 de 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: paso 4, imagen 2 de 2
    • Once the screws have been removed, gently lift the battery out.
  5. Asus Q550LF-BBI7T07 Disc Drive Replacement, Hard Drive: paso 5, imagen 1 de 2 Asus Q550LF-BBI7T07 Disc Drive Replacement, Hard Drive: paso 5, imagen 2 de 2
    • Use the Phillips #0 Screwdriver to unscrew the four silver 5mm screws.
  6. Asus Q550LF-BBI7T07 Disc Drive Replacement: paso 6, imagen 1 de 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: paso 6, imagen 2 de 2
    • Gently disconnect the Hard Drive from the connector cable. Lift it out and remove it.
  7. Asus Q550LF-BBI7T07 Disc Drive Replacement, Disc Drive: paso 7, imagen 1 de 2 Asus Q550LF-BBI7T07 Disc Drive Replacement, Disc Drive: paso 7, imagen 2 de 2
    • Use the Phillips #0 screwdriver to remove the two 7mm Phillips head screws from the metal disc drive holder.
  8. Asus Q550LF-BBI7T07 Disc Drive Replacement: paso 8, imagen 1 de 1
    • Lift the metal disc drive holder off of the disc drive to remove it.
  9. Asus Q550LF-BBI7T07 Disc Drive Replacement: paso 9, imagen 1 de 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: paso 9, imagen 2 de 2
    • Use the Phillips #0 screwdriver to unscrew the one silver 5mm Phillips head screw that connects the disc drive to the motherboard.
  10. Asus Q550LF-BBI7T07 Disc Drive Replacement: paso 10, imagen 1 de 2 Asus Q550LF-BBI7T07 Disc Drive Replacement: paso 10, imagen 2 de 2
    • Slowly slide out the disc drive, keeping it level, to remove it.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 410
