Saltar al contenido principal
Asus Q534U Wi-fi card Replacement
Qué necesitas
  1. Asus Q534U Wi-fi card Replacement, Back Case Removal: paso 1, imagen 1 de 1
    • Make sure the device is turned off and unplugged from the charger.
    • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
    • Pull off the back cover of the laptop.
    • A pry tool may be needed to pull off the back cover.
  2. Asus Q534U Wi-fi card Replacement: paso 2, imagen 1 de 2 Asus Q534U Wi-fi card Replacement: paso 2, imagen 2 de 2
    • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
  3. Asus Q534U Wi-fi card Replacement: paso 3, imagen 1 de 2 Asus Q534U Wi-fi card Replacement: paso 3, imagen 2 de 2
    • Lift up the black tab next to the silver ribbon cable.
    • Pull lightly on the blue tabs until the silver cable is free.
  4. Asus Q534U Wi-fi card Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the 5 marked screws.
    • Gently remove the battery.
    • Do not bend or puncture the laptop's lithium-polymer pattery.
  5. Asus Q534U Wi-fi card Replacement, Wi-Fi card: paso 5, imagen 1 de 1
    • Disconnect the WiFi antenna cables by gently pulling them in an upwards motion.
    • Needle nose pliers can be used as a detaching tool.
  6. Asus Q534U Wi-fi card Replacement: paso 6, imagen 1 de 1
    • Using a Phillips #0 screwdriver, remove the screw holding the WiFi card down.
    • Pull the WiFi card out of the socket toward the fan housing.
Conclusión
Una persona más ha completado esta guía.
Eric Okoko
Miembro Desde 10/19/17
327 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 19
Todo El Tiempo: 2,834
