Saltar al contenido principal
Introducción
This guide will show you how to replace the RAM in your Asus Q534U laptop. Perhaps your laptop is experiencing slow-downs with multiple programs open, signaling that you may need to upgrade to a larger amount of RAM. Or maybe your laptop won’t boot, indicating that your current RAM may be faulty. If you need to upgrade to a larger capacity RAM stick, or if your current RAM is faulty and in need of replacement, this guide will help you through the process.
The RAM is located underneath a metal cover on the motherboard so it will not be immediately visible upon opening the case. However, the metal cover can be easily pried from the motherboard, for it is affixed by a clip mechanism rather than screws or glue. To replace the metal cover, be sure to align all four sides of the cover with each of the clips and simply press it into place.
Partes
No se especificaron partes.
  1. Asus Q534U RAM Replacement, Back Case Removal: paso 1, imagen 1 de 1
    • Make sure the device is turned off and unplugged from the charger.
    • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
    • Pull off the back cover of the laptop.
    • A pry tool may be needed to pull off the back cover.
  2. Asus Q534U RAM Replacement: paso 2, imagen 1 de 2 Asus Q534U RAM Replacement: paso 2, imagen 2 de 2
    • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
  3. Asus Q534U RAM Replacement: paso 3, imagen 1 de 2 Asus Q534U RAM Replacement: paso 3, imagen 2 de 2
    • Lift up the black tab next to the silver ribbon cable.
    • Pull lightly on the blue tabs until the silver cable is free.
  4. Asus Q534U RAM Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the 5 marked screws.
    • Gently remove the battery.
    • Do not bend or puncture the laptop's lithium-polymer pattery.
  5. Asus Q534U RAM Replacement, RAM: paso 5, imagen 1 de 3 Asus Q534U RAM Replacement, RAM: paso 5, imagen 2 de 3 Asus Q534U RAM Replacement, RAM: paso 5, imagen 3 de 3
    • Locate the metal RAM cover
    • Pull the metal tab on the corner of the metal cover to lift the cover from its clips
    • A pry tool may provide a better grip on small tab.
  6. Asus Q534U RAM Replacement: paso 6, imagen 1 de 3 Asus Q534U RAM Replacement: paso 6, imagen 2 de 3 Asus Q534U RAM Replacement: paso 6, imagen 3 de 3
    • While pushing out the metal clips on both sides of the RAM, lift up the RAM to release it
    • Pull the RAM out gently and bring it up from the slot
    • Make sure to pull out first and then pull the RAM up out of place
Conclusión
5 personas más completaron esta guía.
Kyle Whalen
Miembro Desde 17/10/17
181 Reputación
1 Guía escrita
Equipo
2 comentarios
One question: I have this model and have determined that I have a bad stick of RAM. I have removed this stick but still have 8 gigs available. Is there another stick that I m not seeing or is this built in?
Elijah Elliott - Contestar
saame here must be another stick somewhere
SvGGRK - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 30
Ultimos 30 días: 114
Todo El Tiempo: 5,537
