Saltar al contenido principal
Asus Q534U CPU Fan/Heat Sink Replacement
Qué necesitas
  1. Asus Q534U CPU Fan/Heat Sink Replacement, Back Case Removal: paso 1, imagen 1 de 1
    • Make sure the device is turned off and unplugged from the charger.
    • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
    • Pull off the back cover of the laptop.
    • A pry tool may be needed to pull off the back cover.
  2. Asus Q534U CPU Fan/Heat Sink Replacement: paso 2, imagen 1 de 2 Asus Q534U CPU Fan/Heat Sink Replacement: paso 2, imagen 2 de 2
    • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
  3. Asus Q534U CPU Fan/Heat Sink Replacement: paso 3, imagen 1 de 2 Asus Q534U CPU Fan/Heat Sink Replacement: paso 3, imagen 2 de 2
    • Lift up the black tab next to the silver ribbon cable.
    • Pull lightly on the blue tabs until the silver cable is free.
  4. Asus Q534U CPU Fan/Heat Sink Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the 5 marked screws.
    • Gently remove the battery.
    • Do not bend or puncture the laptop's lithium-polymer pattery.
  5. Asus Q534U CPU Fan/Heat Sink Replacement, CPU Fan/Heat Sink: paso 5, imagen 1 de 2 Asus Q534U CPU Fan/Heat Sink Replacement, CPU Fan/Heat Sink: paso 5, imagen 2 de 2
    • Using the iFixit opening tool, gently pry the CPU fan connector out of the socket.
  6. Asus Q534U CPU Fan/Heat Sink Replacement: paso 6, imagen 1 de 2 Asus Q534U CPU Fan/Heat Sink Replacement: paso 6, imagen 2 de 2
    • Move the black cable located around the CPU fan out of the holder.
    • Remove the following 9 screws:
    • Three Phillips screws
    • Six Phillips screws
    • Make sure not to mix up both types of screws.
    • Gently pull vertically on the CPU fan/ heat sink assembly until it is free.
    • Before placing a new CPU fan/heat sink assembly, the CPU and GPU surfaces must be cleaned off and thermal compound must be reapplied.
Conclusión
4 personas más completaron esta guía.
mmedina
Miembro Desde 04/07/16
749 Reputación
2 Guías creadas
Equipo
Un comentario
Is it possible to replace the fan only without removing the full heatsink or is it fused together as one unit?
Bork Bois - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 27
Todo El Tiempo: 2,616
