Introducción
Does your Asus Q525U laptop frequently make strange grinding or ticking sounds? If it does, here is a detailed guide to help fix the issues by replacing the hard drive.
Before beginning this repair, power off your laptop and disconnect from the power adapter.
Qué necesitas
Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
The hard drive is located to the left of the battery and below the motherboard.
Una persona más ha completado esta guía.
