Introducción
If you need to access any of the various components within the Asus Q525U, the back cover must be removed. Since the back cover protects the internal pieces of the laptop from the surrounding environment, careful attention must be made in order to fully remove and replace it.
Before beginning this repair, turn off your device and unplug from the power adapter.
Qué necesitas
Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
Una persona más ha completado esta guía.
