Saltar al contenido principal
Asus Q525U Back Cover Replacement
Qué necesitas
  1. Asus Q525U Back Cover Replacement, Back Cover: paso 1, imagen 1 de 3 Asus Q525U Back Cover Replacement, Back Cover: paso 1, imagen 2 de 3 Asus Q525U Back Cover Replacement, Back Cover: paso 1, imagen 3 de 3
    • Begin by powering off the device and flipping the device over.
    • Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
    • Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
  2. Asus Q525U Back Cover Replacement: paso 2, imagen 1 de 3 Asus Q525U Back Cover Replacement: paso 2, imagen 2 de 3 Asus Q525U Back Cover Replacement: paso 2, imagen 3 de 3
    • Use an opening pick to separate the back cover from the device.
    • For easiest removal, begin by prying at one of the front corners and sliding the tool under the cover in a counter-clockwise motion (to the left) toward the laptop hinge.
  3. Asus Q525U Back Cover Replacement: paso 3, imagen 1 de 3 Asus Q525U Back Cover Replacement: paso 3, imagen 2 de 3 Asus Q525U Back Cover Replacement: paso 3, imagen 3 de 3
    • Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
    • The back cover should be easily removable, allowing full access to all of the internal components.
Conclusión
Una persona más ha completado esta guía.
Equipo
Clemson, Team 2-5, Hunter Spring 2022 Miembro de Clemson, Team 2-5, Hunter Spring 2022
CLEM-HUNTER-S22S2G5
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 575
