Introducción
In this guide you will learn how to remove and replace the Asus Q505UA-BI5T7's speakers for this device. This is a simple process with a minimal amount of tools needed. The replacement of this part should take around only 10 minutes to complete. Please read the troubleshooting page before deciding to remove the speakers.
Qué necesitas
Flip the device over so that the back cover is facing you.
Remove the two 10 mm Philips #1 screws from the top two corners of the back cover of the laptop.
Remove the remaining eight 8 mm Philips #1 screws remaining in the back cover of the laptop.
These are the two device speakers. Locate the right speaker by the battery, and continue to the next step.
