Saltar al contenido principal
Asus Q504UA-BHI5T13 Hard Drive Replacement
Qué necesitas
  1. Asus Q504UA-BHI5T13 Hard Drive Replacement, Back Panel: paso 1, imagen 1 de 1
    • Ensure that the laptop is off so you do not shock yourself.
  2. Asus Q504UA-BHI5T13 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Use the T5 Torx screwdriver to remove the ten 1mm screws located around the back cover.
  3. Asus Q504UA-BHI5T13 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Remove the two rubber pads nearest to you using the metal spudger.
  4. Asus Q504UA-BHI5T13 Hard Drive Replacement: paso 4, imagen 1 de 1
    • Use the Phillips #0 screwdriver to remove the two 4mm screws that are under the rubber pads.
  5. Asus Q504UA-BHI5T13 Hard Drive Replacement: paso 5, imagen 1 de 1
    • Insert any of the plastic opening tools into the seam to separate the back cover (it is recommended to start at the corner of the hinges). If you did it right, then the cover should pop off.
    • Be careful as you may damage the tabs.
  6. Asus Q504UA-BHI5T13 Hard Drive Replacement, Hard Drive: paso 6, imagen 1 de 1
    • Once the back cover is removed, have the laptop facing upside down with the hinges facing toward you.
  7. Asus Q504UA-BHI5T13 Hard Drive Replacement: paso 7, imagen 1 de 1
    • Use the Phillips #0 screwdriver to remove the eight 4mm screws around the hard drive casing (located next to the Right [R] speaker).
    • Start off with the four black outer screws so that the casing can be released from the laptop unit.
    • The next sequence of screws to remove are the four silver screws.
  8. Asus Q504UA-BHI5T13 Hard Drive Replacement: paso 8, imagen 1 de 1
    • Remove the cover.
  9. Asus Q504UA-BHI5T13 Hard Drive Replacement: paso 9, imagen 1 de 2 Asus Q504UA-BHI5T13 Hard Drive Replacement: paso 9, imagen 2 de 2
    • Lift the hard drive and disconnect the hard drive sliding connector.
    • Be careful when removing the connector from the hard drive, as damaging that cable could cause damage to the hard drive.
Conclusión
5 personas más completaron esta guía.
Johnathan Teav
Miembro Desde 10/02/17
456 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S10-G4, Thompson Fall 2017 Miembro de USF Tampa, Team S10-G4, Thompson Fall 2017
USFT-THOMPSON-F17S10G4
4 Miembros
5 Guías creadas
Un comentario
I used your steps to replace the 128GB SSD with a larger drive. When I booted up, the new SSD appeared, the REMOVED 128GB SSD appeared, but the 1TB HHD data drive disappeared. Any tho’ts? Wish I could give you more than 30 points. Thanks. I was down to 17GB on the original drive.
Mark Mikrut - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 31
Todo El Tiempo: 5,919
