Saltar al contenido principal
Asus Q502LA-BSI5T14 Motherboard Replacement
Qué necesitas
  1. Asus Q502LA-BSI5T14 Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Ensure your device is powered off before starting.
    • Flip the laptop over and remove the ten 10 mm Phillips #1 screws securing the back panel.
  2. Asus Q502LA-BSI5T14 Motherboard Replacement: paso 2, imagen 1 de 1
    • Carefully insert a plastic opening tool under one corner of the back panel.
    • Slide the tool along the seam to gently pry the panel up and away from the device.
  3. Asus Q502LA-BSI5T14 Motherboard Replacement: paso 3, imagen 1 de 2 Asus Q502LA-BSI5T14 Motherboard Replacement: paso 3, imagen 2 de 2
    • The battery is the large L-shaped block.
    • Remove the five 5.5 mm Phillips #1 screws securing it.
  4. Asus Q502LA-BSI5T14 Motherboard Replacement: paso 4, imagen 1 de 2 Asus Q502LA-BSI5T14 Motherboard Replacement: paso 4, imagen 2 de 2
    • Using a plastic opening tool, lift the battery straight upward to remove it.
    • There are a series of eight small wires connecting the battery to the motherboard. Make sure you gently lift the battery straight up to disconnect these wires and prevent damage.
  5. Asus Q502LA-BSI5T14 Motherboard Replacement, Motherboard: paso 5, imagen 1 de 2 Asus Q502LA-BSI5T14 Motherboard Replacement, Motherboard: paso 5, imagen 2 de 2
    • Remove the four ribbons connected to the motherboard.
  6. Asus Q502LA-BSI5T14 Motherboard Replacement: paso 6, imagen 1 de 2 Asus Q502LA-BSI5T14 Motherboard Replacement: paso 6, imagen 2 de 2
    • Disconnect the five wires attached to the motherboard by pulling gently. There are three thin wires in the upper left corner.
  7. Asus Q502LA-BSI5T14 Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the two 5 mm Phillips #1 screws attaching the stabilizer to the motherboard
  8. Asus Q502LA-BSI5T14 Motherboard Replacement: paso 8, imagen 1 de 1
    • Remove the four 5 mm Phillips #1 screws around the perimeter of the motherboard.
  9. Asus Q502LA-BSI5T14 Motherboard Replacement: paso 9, imagen 1 de 2 Asus Q502LA-BSI5T14 Motherboard Replacement: paso 9, imagen 2 de 2
    • Remove the six 5 mm Phillips #1 screws securing the silver plates to the motherboard.
    • Open the laptop approximately 1/2" to loosen the hinge and release the motherboard.
  10. Asus Q502LA-BSI5T14 Motherboard Replacement: paso 10, imagen 1 de 1
    • Gently lift the motherboard out and away from the laptop.
Conclusión
3 personas más completaron esta guía.
Mary Kounelas
Miembro Desde 09/25/17
715 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S4-G1, Eyestone Fall 2017 Miembro de USF Tampa, Team S4-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S4G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 1,594
