Introducción
The keyboard allows communication between the user and the laptop. If your keyboard is not responding, follow this guide to learn how to replace it.
Qué necesitas
Flip the laptop over and remove the ten 10 mm Phillips #1 screws securing the back panel.
Remove the one 5 mm Phillips #1 screw.
Pull out the green plastic in order to free the keyboard underneath.
Una persona más ha completado esta guía.
Un comentario
Step 4 was misleading. It should have unplugged the cable before lifting the battery. I broke my battery connector off the mobo by following these directions. Lift straight up? That’s silly given how short the battery connection cable is.
