Saltar al contenido principal
Asus Q501LA-BBI6T03 Hard Drive Replacement
Qué necesitas
  1. Asus Q501LA-BBI6T03 Hard Drive Replacement, Back Panel: paso 1, imagen 1 de 1
    • Ensure the laptop is powered down before continuing.
    • Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
  2. Asus Q501LA-BBI6T03 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Use the spudger to pry open the rear cover at either hinge.
  3. Asus Q501LA-BBI6T03 Hard Drive Replacement: paso 3, imagen 1 de 2 Asus Q501LA-BBI6T03 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Grab the cover with your fingers and gently lift it away from the board.
    • Be careful not to break any tabs on the cover when lifting it off.
  4. Asus Q501LA-BBI6T03 Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 1
    • Remove the four 3mm Phillips #0 screws shown.
  5. Asus Q501LA-BBI6T03 Hard Drive Replacement: paso 5, imagen 1 de 1
    • Take hard drive out of the port by sliding the component to the left.
    • There is only one way it comes out of the connector. If it seems too hard to push out you are probably going the wrong way.
  6. Asus Q501LA-BBI6T03 Hard Drive Replacement: paso 6, imagen 1 de 1
    • Once the hard drive has been removed from the connector, use your thumb to get under and lift the hard drive out.
Conclusión
4 personas más completaron esta guía.
Aodhan Arias
Miembro Desde 01/25/17
288 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 8-1, Banghart Winter 2017 Miembro de Cal Poly, Team 8-1, Banghart Winter 2017
CPSU-BANGHART-W17S8G1
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 2,685
