Saltar al contenido principal
Asus Q500A Hard Drive Replacement
Qué necesitas
  1. Asus Q500A Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Flip device onto backside
  2. Asus Q500A Hard Drive Replacement: paso 2, imagen 1 de 1
    • Use a J0 screwdriver bit to remove both screws on the back-plate, found at the bottom of device.
    • Remove back-plate.
    • Note: Use prying tool if your having issues lifting back-plate.
  3. Asus Q500A Hard Drive Replacement: paso 3, imagen 1 de 2 Asus Q500A Hard Drive Replacement: paso 3, imagen 2 de 2
    • Remove 4 screws from the metal hard-drive case. There will be one in each corner.
    • Remove the hard-drive case from the device.
  4. Asus Q500A Hard Drive Replacement: paso 4, imagen 1 de 1
    • Remove the hard-drive. It will be connected to the integrated sata-port in the device.
    • Place hard-drive into slot and connect to the integrated sata port.
    • Place hard drive case back on top of the new hard-drive.
    • Screw in the four screws on the hard-drive case.
  5. Asus Q500A Hard Drive Replacement: paso 6, imagen 1 de 1
    • Place back-plate back on device.
    • Screw in the 2 screws on the back of the plate.
Conclusión
2 personas más completaron esta guía.
cameron
Miembro Desde 02/15/17
319 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 12-5, Eyestone Spring 2017 Miembro de USF Tampa, Team 12-5, Eyestone Spring 2017
USFT-EYESTONE-S17S12G5
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 965
