Saltar al contenido principal
Asus Q500A Battery Replacement
  1. Asus Q500A Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Flip device onto backside.
  2. Asus Q500A Battery Replacement: paso 2, imagen 1 de 1
    • Locate the two sliding locks.
    • Slide the sliding lock 1 to the right to unlock it .
    • There should be a red marker to indicate that it is unlocked. This lock will stay unlocked until slid back into the locked position.
  3. Asus Q500A Battery Replacement: paso 3, imagen 1 de 1
    • Slide the sliding lock 2 to the left to unlock it.
    • There will not be any indicator that it is unlocked. This lock will relock if you do not continue to push it to the left.
  4. Asus Q500A Battery Replacement: paso 4, imagen 1 de 1
    • While the first and second lock are unlocked, slide the battery out to remove it.
    • When reinserting the replacement battery, make sure to slide sliding lock 1 back into the locked position. Otherwise the battery may come loose.
Conclusión
cameron
Miembro Desde 02/15/17
319 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 12-5, Eyestone Spring 2017 Miembro de USF Tampa, Team 12-5, Eyestone Spring 2017
USFT-EYESTONE-S17S12G5
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 497
