Introducción
This guide will take you through the steps needed to replace the battery in your Asus Q325U.
Qué necesitas
Remove the seven 5mm screws around the battery using a Phillips #00 screwdriver.
4 personas más completaron esta guía.
7 comentarios
Hello,
Can you point me to a place to purchase a replacement battery? Thanks,
Dan Goldman, daniel.goldman@physics.gatech.edu
Would recommend the screw size be ad to the guide please.
Like Dan, I need to get a replacement battery. Any idea where it can be purchased (safely)?
Thanks :D
not able to get beyond step 4. Any ideas how to open the small screws. I tried PH#000, and many others, but no luck
the battery shown here is not the same for the Q325U, different battery connectors.
