Saltar al contenido principal
Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement
Qué necesitas
  1. Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement, Fan and Heat Sink: paso 1, imagen 1 de 2 Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement, Fan and Heat Sink: paso 1, imagen 2 de 2
    • Unscrew the ten 10mm Phillips #0 screws.
    • Use the plastic opening tool along the side of the laptop to pry open.
  2. Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement: paso 2, imagen 1 de 2 Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement: paso 2, imagen 2 de 2
    • Remove the seven 4mm Phillips #0 screws.
    • Gently pull the connector.
  3. Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement: paso 3, imagen 1 de 1
    • Lift the heat sink and fan assembly, and you are done!
    • There maybe a little resistance to being pulled up since the heat sink is attached to the CPU with thermal paste
Conclusión
Una persona más ha completado esta guía.
Equipo
IUPUI, Team S1-G2, Hovde Fall 2018 Miembro de IUPUI, Team S1-G2, Hovde Fall 2018
IUPUI-HOVDE-F18S1G2
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 136
