Saltar al contenido principal
Asus Q302UA-BHI5T20 Battery Replacement
Qué necesitas
  1. Asus Q302UA-BHI5T20 Battery Replacement, Battery: paso 1, imagen 1 de 2 Asus Q302UA-BHI5T20 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Place laptop upside down
    • Remove the cover by unscrewing the 10 screws highlighted in the picture
    • Use PH0 bit to remove the 1cm black screws
  2. Asus Q302UA-BHI5T20 Battery Replacement: paso 2, imagen 1 de 2 Asus Q302UA-BHI5T20 Battery Replacement: paso 2, imagen 2 de 2
    • Unscrew the 5, 5mm screws with the PH0 bit
    • Lift up the battery connector, indicated in yellow
    • Remove the battery by lifting it in upward motion pulling it towards
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 549
