Introducción
The Wi-Fi Card is responsible for transmitting data the same way a cell phone or radio does, through radio waves. Your Wi-Fi Card should be able to pick up a signal from the nearby radios using its tiny antennas. If you are having problems with connecting to the internet using your Wi-Fi Card also known as the Local Area Network Card (LAN), you can use this guide to replace your Wi-Fi Card.
Qué necesitas
To start, turn off the laptop and disconnect the power cable.
Flip the laptop over so the back panel is visible.
Use tweezers or your fingers to disconnect the Wi-Fi card's power connector.
