Saltar al contenido principal
Asus Q200E-CT144H Speaker Replacement
Qué necesitas
  1. Asus Q200E-CT144H Speaker Replacement, Back Cover: paso 1, imagen 1 de 1
    • To start, turn off the laptop and disconnect the power cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Flip the laptop over so the back panel is visible.
  2. Asus Q200E-CT144H Speaker Replacement: paso 2, imagen 1 de 1
    • Remove the 9 screws holding the cover in place by taking a Phillips #00 Screwdriver and turning it counterclockwise.
  3. Asus Q200E-CT144H Speaker Replacement: paso 3, imagen 1 de 2 Asus Q200E-CT144H Speaker Replacement: paso 3, imagen 2 de 2
    • Use an iFixit opening tool to lift the back cover and remove it from the laptop.
  4. Asus Q200E-CT144H Speaker Replacement, Battery: paso 4, imagen 1 de 2 Asus Q200E-CT144H Speaker Replacement, Battery: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Remove the battery connector by using tweezers to lift up on it.
  5. Asus Q200E-CT144H Speaker Replacement: paso 5, imagen 1 de 2 Asus Q200E-CT144H Speaker Replacement: paso 5, imagen 2 de 2
    • Remove the nine Phillips #00 screws that hold the battery in place.
    • There is one 9.2mm screw, four 4.7mm screws, and four 5.7mm screws.
  6. Asus Q200E-CT144H Speaker Replacement: paso 6, imagen 1 de 2 Asus Q200E-CT144H Speaker Replacement: paso 6, imagen 2 de 2
    • Remove the battery from the battery bay.
  7. Asus Q200E-CT144H Speaker Replacement, Speaker: paso 7, imagen 1 de 1
    Comprar
    • Use tweezers to disconnect the speaker's main power connectors.
  8. Asus Q200E-CT144H Speaker Replacement: paso 8, imagen 1 de 2 Asus Q200E-CT144H Speaker Replacement: paso 8, imagen 2 de 2
    • Use a metal spudger to pry the speaker housing from the laptop.
    • There will be glue holding the speaker housing to the laptop.
  9. Asus Q200E-CT144H Speaker Replacement: paso 9, imagen 1 de 2 Asus Q200E-CT144H Speaker Replacement: paso 9, imagen 2 de 2
    • Remove the right speaker from its housing.
    • Use tweezers to remove the black and white wire from its groove.
    • The black and white wire connects the speaker housings together.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 122
