Saltar al contenido principal
Asus Q200E-CT144H Screen Replacement
Qué necesitas
  1. Asus Q200E-CT144H Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Turn off the laptop and disconnect the power cable.
    • If the laptop is powered on, it could cause an electric shock.
    • Open the laptop and place it on a hard, flat surface with the screen facing up.
  2. Asus Q200E-CT144H Screen Replacement: paso 2, imagen 1 de 2 Asus Q200E-CT144H Screen Replacement: paso 2, imagen 2 de 2
    • Take a metal spudger and insert it under the screen.
    • Slowly move the spudger across the length of the screen, separating the sections.
  3. Asus Q200E-CT144H Screen Replacement: paso 3, imagen 1 de 1
    • Remove the four 3.3mm Phillips #00 screws.
  4. Asus Q200E-CT144H Screen Replacement: paso 4, imagen 1 de 1
    • Pull apart the screen from the casing of the laptop.
    • Disconnect the power connector using tweezers.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 267
