Saltar al contenido principal
Asus Padfone X Mini Camera Replacement
Qué necesitas
  1. Asus Padfone X Mini Camera Replacement, Speaker: paso 1, imagen 1 de 1
    • With the phone facing down, look at the bottom right side corner and there should be a groove. Use a plastic opening tool and lift up to remove outside cover.
    • This is not the cover with the speaker attached.
  2. Asus Padfone X Mini Camera Replacement: paso 2, imagen 1 de 1
    • Lift the battery out from the top of the device.
  3. Asus Padfone X Mini Camera Replacement: paso 3, imagen 1 de 1
    • Around the perimeter, there should be 10 2 mm T5 Torx screws. Take them out.
    • Remove the cover.
  4. Asus Padfone X Mini Camera Replacement: paso 4, imagen 1 de 1
    • Turn the cover over.
    • The speaker is attached to the inside of the cover and to the right of the camera hole.
  5. Asus Padfone X Mini Camera Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Remove speaker with standard tweezers to minimize damage, and replace.
  6. Asus Padfone X Mini Camera Replacement, Screen: paso 6, imagen 1 de 1
    • Detach the black connector on the left hand side of the motherboard.
    • Don't completely remove the black connector.
  7. Asus Padfone X Mini Camera Replacement: paso 7, imagen 1 de 1
    • Disconnect silver connector from the motherboard. It is located on the left hand side above the black connector.
  8. Asus Padfone X Mini Camera Replacement: paso 8, imagen 1 de 2 Asus Padfone X Mini Camera Replacement: paso 8, imagen 2 de 2
    • Remove motherboard and replace screen.
  9. Asus Padfone X Mini Camera Replacement, Camera: paso 9, imagen 1 de 1
    • Turn over the motherboard.
  10. Asus Padfone X Mini Camera Replacement: paso 10, imagen 1 de 1
    Comprar
    • Using tweezers pull out the connector that connects the camera to the motherboard.
  11. Asus Padfone X Mini Camera Replacement: paso 11, imagen 1 de 2 Asus Padfone X Mini Camera Replacement: paso 11, imagen 2 de 2
    • Take out the camera.
    • Put in the new camera by sliding the camera connector into the receiver.
Conclusión
James Jackson
Miembro Desde 09/18/18
97 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 192
