Saltar al contenido principal
Asus Padfone 2 Vibrator Replacement
Qué necesitas
  1. Asus Padfone 2 Vibrator Replacement, Power Down Device: paso 1, imagen 1 de 1
    • Hold down the power button
  2. Asus Padfone 2 Vibrator Replacement, Remove Back Plate: paso 2, imagen 1 de 3 Asus Padfone 2 Vibrator Replacement, Remove Back Plate: paso 2, imagen 2 de 3 Asus Padfone 2 Vibrator Replacement, Remove Back Plate: paso 2, imagen 3 de 3
    • Use plastic opening tool to pry off the back cover of the phone.
  3. Asus Padfone 2 Vibrator Replacement, Battery Removal: paso 3, imagen 1 de 3 Asus Padfone 2 Vibrator Replacement, Battery Removal: paso 3, imagen 2 de 3 Asus Padfone 2 Vibrator Replacement, Battery Removal: paso 3, imagen 3 de 3
    • Remove the warning sticker that covers the battery plug and connecting cord.
    • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
    • The battery is held down with adhesive. Be careful not to damage battery or connecting cord.
    • Disconnect battery connecting cord using tweezers.
  4. Asus Padfone 2 Vibrator Replacement, Remove Internal Back Plate: paso 4, imagen 1 de 2 Asus Padfone 2 Vibrator Replacement, Remove Internal Back Plate: paso 4, imagen 2 de 2
    • Use T5 Torx screwdriver to remove 14 screws from internal back plate.
    • Use of magnetic pad will help with keeping track of screws.
    • Once screws are out, remove the plate.
  5. Asus Padfone 2 Vibrator Replacement, Removal of A68 Vibrator: paso 5, imagen 1 de 2 Asus Padfone 2 Vibrator Replacement, Removal of A68 Vibrator: paso 5, imagen 2 de 2
    • Use tweezers to remove motor from housing, pulling the plug downward away from the phone.
    • Use tweezers to unplug the device from the circuit board.
Conclusión
2 personas más completaron esta guía.
Zach Standridge
Miembro Desde 09/25/14
350 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 5-4, Mcgee Fall 2014 Miembro de USF Tampa, Team 5-4, Mcgee Fall 2014
USFT-MCGEE-F14S5G4
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,372
