Saltar al contenido principal
Asus Padfone 2 Battery Replacement
Qué necesitas
  1. Asus Padfone 2 Battery Replacement, Power off phone: paso 1, imagen 1 de 1
    • Hold down power button to shut off phone.
  2. Asus Padfone 2 Battery Replacement, Remove back cover of phone: paso 2, imagen 1 de 2 Asus Padfone 2 Battery Replacement, Remove back cover of phone: paso 2, imagen 2 de 2
    • Use plastic opening tool to pry off the back cover of the phone.
  3. Asus Padfone 2 Battery Replacement, Battery Removal: paso 3, imagen 1 de 3 Asus Padfone 2 Battery Replacement, Battery Removal: paso 3, imagen 2 de 3 Asus Padfone 2 Battery Replacement, Battery Removal: paso 3, imagen 3 de 3
    • Remove the warning sticker that covers the battery plug and connecting cord.
    • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
    • The battery is held down with adhesive. Be careful not to damage battery or connecting cord
    • Disconnect battery connecting cord using tweezers.
Conclusión
6 personas más completaron esta guía.
Zach Standridge
Miembro Desde 09/25/14
350 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 5-4, Mcgee Fall 2014 Miembro de USF Tampa, Team 5-4, Mcgee Fall 2014
USFT-MCGEE-F14S5G4
4 Miembros
7 Guías creadas
Un comentario
Pull the battery connector towards USB. You will break it if you pull it up, as I did.
I wouldn’t recommend metal tweezers as it could shortcut the battery.
Los Karlos - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 5,860
