Qué necesitas
Remove the warning sticker that covers the battery plug and connecting cord.
Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
Disconnect battery connecting cord using tweezers.
Use T5 Torx screwdriver to remove 14 screws from internal back plate.
Once screws are out, remove the plate.
Use tweezers to unplug the sub cables from the circuit board and housing.
Casi Terminas!
Conclusión
