Saltar al contenido principal
Asus N551JQ thermal paste replacement
Qué necesitas
  1. Asus N551JQ thermal paste replacement, Thermal paste: paso 1, imagen 1 de 1
    • Shut down your laptop.
    • Turn your laptop upside down.
  2. Asus N551JQ thermal paste replacement: paso 2, imagen 1 de 2 Asus N551JQ thermal paste replacement: paso 2, imagen 2 de 2
    • Remove the battery, by sliding the slide.
    • Lift up the battery / pull it out.
  3. Asus N551JQ thermal paste replacement: paso 3, imagen 1 de 1
    • Remove all the screws.
    • Warning: the yellow screws are longer then the rest. Keep them part!
  4. Asus N551JQ thermal paste replacement: paso 4, imagen 1 de 2 Asus N551JQ thermal paste replacement: paso 4, imagen 2 de 2
    • Remove the DVD drive.
    • Mine is green, because it's an HDD caddy.
    • Optionally use a tool.
  5. Asus N551JQ thermal paste replacement: paso 5, imagen 1 de 1
    • Remove the two screws which were under the DVD drive.
    • These are shorter then the rest. Keep them part!
  6. Asus N551JQ thermal paste replacement: paso 6, imagen 1 de 2 Asus N551JQ thermal paste replacement: paso 6, imagen 2 de 2
    • Remove the bar at the bottom of the laptop, by sliding it downwards.
  7. Asus N551JQ thermal paste replacement: paso 7, imagen 1 de 1
    • To prevent damage, remove your memory.
    • Your memory is probably just one, mine is extended.
    • The black lines are to protect some data.
  8. Asus N551JQ thermal paste replacement: paso 8, imagen 1 de 2 Asus N551JQ thermal paste replacement: paso 8, imagen 2 de 2
    • Release the marked connector.
    • Release the Wi-Fi antennas.
  9. Asus N551JQ thermal paste replacement: paso 9, imagen 1 de 1
    • Remove the marked screws.
  10. Asus N551JQ thermal paste replacement: paso 10, imagen 1 de 3 Asus N551JQ thermal paste replacement: paso 10, imagen 2 de 3 Asus N551JQ thermal paste replacement: paso 10, imagen 3 de 3
    • Carefully remove the HDD, by pulling the black plastic thing.
  11. Asus N551JQ thermal paste replacement, Opening case: paso 11, imagen 1 de 2 Asus N551JQ thermal paste replacement, Opening case: paso 11, imagen 2 de 2
    • This step is for the bottom side of the laptop (where HDD and memory are). Using an opening pick, to not damage the case.
    • Starting in an edge, pull the pick in. Slide left-right/right-left, to create an opening.
    • No problem when you hear a click-sound.
    • When there is an opening, use a spudger to seperate the rest of the downside of the case. Slide it trough the whole downside.
    • Slide further with the spudger to the side where are the least ports (one USB port). Optionally use a opening pick, if necessary.
  12. Asus N551JQ thermal paste replacement, Opening case - network-side: paso 12, imagen 1 de 1
    • Use the spudger from the downside edge, until you reach the network port.
    • Behind the network port, try to insert an opening pick, to create a new opening.
    • When done, slide with the spudger to the rest of the network-side.
  13. Asus N551JQ thermal paste replacement, Opening case - battery side: paso 13, imagen 1 de 1
    • Use opening pick to create an opening at battery side. Try to open the battery side with opening pick only. Only when necessary use the spudger on this side.
  14. Asus N551JQ thermal paste replacement, Removing the case: paso 14, imagen 1 de 2 Asus N551JQ thermal paste replacement, Removing the case: paso 14, imagen 2 de 2
    • Lift up the case (with finger/hand), so the whole case is released.
    • Open the laptop. Turn the laptop upside down.
    • Don't try to remove the case, it's connected to the screen!
  15. Asus N551JQ thermal paste replacement: paso 15, imagen 1 de 3 Asus N551JQ thermal paste replacement: paso 15, imagen 2 de 3 Asus N551JQ thermal paste replacement: paso 15, imagen 3 de 3
    • Pull down the keyboard, but not too far.
    • Release the screen connector, by pulling the plastic thing (marked red).
    • Make the laptop in an 90 degree edge, then carefully pull out the case.
    • STOP when hearing some cracking sounds! Try pull out an other way (make small movements). When something is blocking, check if released all connectors!
  16. Asus N551JQ thermal paste replacement, Remove the cooling unit: paso 16, imagen 1 de 3 Asus N551JQ thermal paste replacement, Remove the cooling unit: paso 16, imagen 2 de 3 Asus N551JQ thermal paste replacement, Remove the cooling unit: paso 16, imagen 3 de 3
    • Remove the red marked screws and the red marked connector.
    • Optionally remove the yellow marked screws.
  17. Asus N551JQ thermal paste replacement: paso 17, imagen 1 de 2 Asus N551JQ thermal paste replacement: paso 17, imagen 2 de 2
    • Release the aluminum isolation layer a little bit, so it makes possible removing the cooling unit.
    • Remove the full cooling unit (lift it up).
  18. Asus N551JQ thermal paste replacement, Cleaning chips: paso 18, imagen 1 de 3 Asus N551JQ thermal paste replacement, Cleaning chips: paso 18, imagen 2 de 3 Asus N551JQ thermal paste replacement, Cleaning chips: paso 18, imagen 3 de 3
    • Clean the processor and videocard chip, so the thermal paste will be removed.
    • If the paste is dried out, use some water or alcohol, not to much! Make sure to dry both.
  19. Asus N551JQ thermal paste replacement, Cleaning cooling unit: paso 19, imagen 1 de 2 Asus N551JQ thermal paste replacement, Cleaning cooling unit: paso 19, imagen 2 de 2
    • Remove the (dried) thermal paste of the cooling unit.
    • Clean the dust, by using compressed air, or an paint brush.
    • When using an compressor/compressed air, block the fan, so it can not spin/rotate. Else it will damage!
  20. Asus N551JQ thermal paste replacement, Apply new thermal paste: paso 20, imagen 1 de 3 Asus N551JQ thermal paste replacement, Apply new thermal paste: paso 20, imagen 2 de 3 Asus N551JQ thermal paste replacement, Apply new thermal paste: paso 20, imagen 3 de 3
    • Thermal paste is available in different versions.
    • Put one drop on the processor, two on the videocard. Use not to much (could counteract the cooling process).
    • Gently divide the thermal paste like on the picture, over the whole "metal" part of the chips.
  21. Asus N551JQ thermal paste replacement: paso 21, imagen 1 de 1
    • Pull back the cooling unit, and gently move it with two fingers, so the cooling paste wil divide better.
    • When done, remove the unit and check if the paste is divided well.
    • Repeat if necessary.
Conclusión
While disassemble and reassemble, remove every dust you see, for better performance.
Let me know if this guide helped you!
8 personas más completaron esta guía.
Marvin Arets
Miembro Desde 10/22/17
390 Reputación
1 Guía escrita
5 comentarios
Thanks for your guide! Is it possible to make a guide to replace the LED IPS screen from the N551JQ? Mine is black after a crash.
Geoffrey van Oosterhout - Contestar
I think this is not very difficult, mostly you can simply pull off the plastic frame that is over your LCD (be carefull with pulling off!). You can pull it off with your fingers starting inside.
(Plastic frame can damage, but they are not expensive).
Then remove some screws, LCD will release, but it is still connected with some cables on the backside.
Try it and make pictures, so you can create a guide :).
Marvin Arets -
Thanks for the guide! Sadly after doing this I found that my right side I/O (audio out and 1x usb port) no longer works. Any suggestions as to what could be the cause and how to solve this?
I'm pretty sure I have done everything by the book so I'm really bashing my head against the wall right now, I've never had this occur when replacing thermal paste before.
Thanks for your help
michelangelo dini - Contestar
Maybe you released/loosened its connector or you damaged the board?
Marvin Arets -
It was indeed a ribbon cable which had come loose (luckily no mobo damage). Something that I noticed is that the factory thermal paste had been applied all over the vram chips, as well as on those chips labeled “R36” directly “south” of the gpu die. I have the JW version of this laptop, which has some thin rectangular metal plates attached to the heatpipes, so as to cover the vram chips and others surrounding the gpu die. I found that kinda strange, seeing that the JQ version does not have this at all.
michelangelo dini -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 23
Todo El Tiempo: 4,561
