Introducción
You will learn how to replace the SIM card reader. Review this guide if you are having difficulties with the SIM card reader. In order to replace the SIM card reader, you have to remove the battery. Please use our Asus MeMO Pad HD 8 ME180A Battery Replacement Guide to do so prior to starting.
Herramientas
Partes
No se especificaron partes.
Use a plastic opening tool to separate the back half from the front half.
Pull the back panel away from the device.
Upon removal of the motherboard, desolder the pins that hold the SIM card reader in place.
Using a pair of tweezers, if desired, pull the sim card straight out.
