Saltar al contenido principal
Asus MeMO Pad HD 8 ME180A Camera Replacement
Qué necesitas
  1. Asus MeMO Pad HD 8 ME180A Camera Replacement, Battery: paso 1, imagen 1 de 2 Asus MeMO Pad HD 8 ME180A Camera Replacement, Battery: paso 1, imagen 2 de 2
    • Use a plastic opening tool to separate the back half from the front half.
    • Pull the back panel away from the device.
    • The volume buttons can fall out of the case. Be careful not to lose them.
  2. Asus MeMO Pad HD 8 ME180A Camera Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
  3. Asus MeMO Pad HD 8 ME180A Camera Replacement: paso 3, imagen 1 de 3 Asus MeMO Pad HD 8 ME180A Camera Replacement: paso 3, imagen 2 de 3 Asus MeMO Pad HD 8 ME180A Camera Replacement: paso 3, imagen 3 de 3
    • Lift the white bar on the ZIF connector and pull the metal connector out.
  4. Asus MeMO Pad HD 8 ME180A Camera Replacement: paso 4, imagen 1 de 2 Asus MeMO Pad HD 8 ME180A Camera Replacement: paso 4, imagen 2 de 2
    • Using your spudger, press down on the two spots shown in order to release the cables.
    • Ensure that the touchscreen cables are fully disconnected.
  5. Asus MeMO Pad HD 8 ME180A Camera Replacement: paso 5, imagen 1 de 2 Asus MeMO Pad HD 8 ME180A Camera Replacement: paso 5, imagen 2 de 2
    • Using a PH#0 screwdriver, remove the twelve silver 3.2 mm screws.
    • Pull the battery out.
  6. Asus MeMO Pad HD 8 ME180A Camera Replacement, Motherboard: paso 6, imagen 1 de 1
    • Disconnect GPS Antenna cable.
  7. Asus MeMO Pad HD 8 ME180A Camera Replacement: paso 7, imagen 1 de 1
    • Flip the latch and pull the ribbon cable to disconnect the ZIF connector.
  8. Asus MeMO Pad HD 8 ME180A Camera Replacement: paso 8, imagen 1 de 1
  9. Asus MeMO Pad HD 8 ME180A Camera Replacement: paso 9, imagen 1 de 2 Asus MeMO Pad HD 8 ME180A Camera Replacement: paso 9, imagen 2 de 2
    • Use a PH#0 screwdriver to unscrew the six 3.0 mm black screws.
    • Lift the motherboard straight up to remove.
  10. Asus MeMO Pad HD 8 ME180A Camera Replacement, Camera: paso 10, imagen 1 de 1
    • Upon removal of the motherboard, flip the motherboard to the side so the front-face camera faces you.
    • Remove the front facing camera.
  11. Asus MeMO Pad HD 8 ME180A Camera Replacement: paso 11, imagen 1 de 1
    • Upon removal of the front-face camera, flip your device to the side so the back-face camera faces you.
    • Using a pair of tweezers, grab the back-face camera and pull it straight out.
Conclusión
Equipo
USF Tampa, Team 2-5, Nance Fall 2016 Miembro de USF Tampa, Team 2-5, Nance Fall 2016
USFT-NANCE-F16S2G5
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 245
