Saltar al contenido principal
Asus MeMO Pad HD 7 Speaker Assembly Replacement
Qué necesitas
  1. Asus MeMO Pad HD 7 Speaker Assembly  Replacement, Remove Rear Panel: paso 1, imagen 1 de 3 Asus MeMO Pad HD 7 Speaker Assembly  Replacement, Remove Rear Panel: paso 1, imagen 2 de 3 Asus MeMO Pad HD 7 Speaker Assembly  Replacement, Remove Rear Panel: paso 1, imagen 3 de 3
    • Carefully remove the back panel by using a plastic opening tool to remove the panel off the device.
    • Pull the back panel away from the device.
    • The volume buttons can fall out of the case. Pay attention so as not to lose them.
  2. Asus MeMO Pad HD 7 Speaker Assembly  Replacement: paso 2, imagen 1 de 1
    • Unlock the ZIF connectors on the data cables.
    • Raise the white locking tabs by lifting their upper edge - furthest from the battery - they hinge across the width of the connector.
    • Remove the cable from its slot by gently pulling downward on the tabs.
    • Check that the touchscreen cables are fully seated when reassembling or touchscreen may have unresponsive areas.
  3. Asus MeMO Pad HD 7 Speaker Assembly  Replacement: paso 3, imagen 1 de 1
    • Locate the battery connector by following the wires that come from the top right of the battery. To disconnect the battery just lift up gently on the wires. Use a spudger or blue plastic opening tool to gently lift the wires if it is hard to get a grip.
  4. Asus MeMO Pad HD 7 Speaker Assembly  Replacement, Remove Battery: paso 4, imagen 1 de 3 Asus MeMO Pad HD 7 Speaker Assembly  Replacement, Remove Battery: paso 4, imagen 2 de 3 Asus MeMO Pad HD 7 Speaker Assembly  Replacement, Remove Battery: paso 4, imagen 3 de 3
    • Using a spudger carefully pry the battery up. It is glued down so slight pressure may be needed.
    • The battery has a soft casing, be careful not to tear the battery casing as chemicals could leak out.
  5. Asus MeMO Pad HD 7 Speaker Assembly  Replacement, Speaker Assembly: paso 5, imagen 1 de 1
    • Unscrew two Philip's #000 2 mm screws located on the left and right side of the speaker housing.
  6. Asus MeMO Pad HD 7 Speaker Assembly  Replacement: paso 6, imagen 1 de 1
    • Locate the speaker wires to the left side of the battery. Remove the connector by pulling up gently or prying with a tool if you can not get a good grip.
  7. Asus MeMO Pad HD 7 Speaker Assembly  Replacement: paso 7, imagen 1 de 2 Asus MeMO Pad HD 7 Speaker Assembly  Replacement: paso 7, imagen 2 de 2
    • Pry the GPS Antenna cable straight up using a spudger or similar prying tool. It will be the grey wire that runs up the right side of the device coming from the speaker housing up to the logic board.
  8. Asus MeMO Pad HD 7 Speaker Assembly  Replacement: paso 8, imagen 1 de 1
    • Using a spudger, carefully pry the GPS antenna from the bottom of the speaker housing.
    • With the GPS antenna removed from the bottom of the speaker housing it can be removed from the device.
Conclusión
3 personas más completaron esta guía.
Julien Daigle
Miembro Desde 01/20/15
1,235 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 11-3, Blackwell Winter 2015 Miembro de USF Tampa, Team 11-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G3
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 8
Todo El Tiempo: 1,003
