Introducción
This guide will step you through replacing the GPS Antenna on your Asus Tablet. This process is straight forward and should not be too difficult.
Qué necesitas
Carefully remove the back panel by using a plastic opening tool to remove the panel off the device.
Pull the back panel away from the device.
Using a spudger carefully pry the battery up. It is glued down so slight pressure may be needed.
Pry the GPS Antenna cable straight up using a spudger or similar prying tool. It will be the grey wire that runs up the right side of the device coming from the speaker housing up to the motherboard.
2 personas más completaron esta guía.
