Saltar al contenido principal
Asus MeMO Pad 7 ME176C Speaker Replacement
Qué necesitas
  1. Asus MeMO Pad 7 ME176C Speaker Replacement, Speakers: paso 1, imagen 1 de 2 Asus MeMO Pad 7 ME176C Speaker Replacement, Speakers: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    iFixit Opening Tool
    $1.99
    • Make sure the device is turned off.
    • Carefully insert the opening tool on the edge of the phone.
    • Slowly lift up the panel from the device and repeat the process on the other side.
  2. Asus MeMO Pad 7 ME176C Speaker Replacement: paso 2, imagen 1 de 3 Asus MeMO Pad 7 ME176C Speaker Replacement: paso 2, imagen 2 de 3 Asus MeMO Pad 7 ME176C Speaker Replacement: paso 2, imagen 3 de 3
    • To disconnect the ZIF connectors. Place the metal spudger underneath the ZIF cable and gently pull it outward.
    • ZIF connectors are fragile, so work with caution.
  3. Asus MeMO Pad 7 ME176C Speaker Replacement: paso 3, imagen 1 de 3 Asus MeMO Pad 7 ME176C Speaker Replacement: paso 3, imagen 2 de 3 Asus MeMO Pad 7 ME176C Speaker Replacement: paso 3, imagen 3 de 3
    • The battery connector is located on the right-hand side of the device
    • To disconnect the battery connector. Use tweezers, and carefully lift up the wire.
    • Remove the battery.
  4. Asus MeMO Pad 7 ME176C Speaker Replacement: paso 4, imagen 1 de 1
    • Using a Philips Head Screwdriver PH000, locate the 2.6mm screws and gently unscrew them .
    • Place these screws somewhere you will remember.
    • Applying too much pressure onto the screen may cause it to break.
  5. Asus MeMO Pad 7 ME176C Speaker Replacement: paso 5, imagen 1 de 3 Asus MeMO Pad 7 ME176C Speaker Replacement: paso 5, imagen 2 de 3 Asus MeMO Pad 7 ME176C Speaker Replacement: paso 5, imagen 3 de 3
    • Using tweezers, disconnect the speaker cable connected to the motherboard.
    • Be sure not to damage other components on the motherboard.
    • After that remove the speaker system completely.
  6. Asus MeMO Pad 7 ME176C Speaker Replacement: paso 6, imagen 1 de 1
    • Now you can attach a new speaker!
Conclusión
Maxime
Miembro Desde 09/26/17
101 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S6-G3, Banghart Fall 2017 Miembro de Cal Poly, Team S6-G3, Banghart Fall 2017
CPSU-BANGHART-F17S6G3
Miembros de 5
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 258
