Saltar al contenido principal
Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement
Qué necesitas
  1. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement, LCD Screen Assembly: paso 1, imagen 1 de 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement, LCD Screen Assembly: paso 1, imagen 2 de 2
    • Insert plastic opening tool in between screen and back cover to create initial separation between the two.
    • Then run plastic opening tool along end of screen to fully separate back cover from screen.
  2. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: paso 2, imagen 1 de 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: paso 2, imagen 2 de 2
    • Remove screws (2.6mm) connecting speaker to hard frame with Phillips head screw driver (PH000).
  3. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: paso 3, imagen 1 de 1
    • Disconnect speaker wire from motherboard using metal pronged tweezers.
  4. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: paso 4, imagen 1 de 1
    • Remove the screws (2.6mm) connecting the motherboard and battery tray to the hard frame with Phillip's head screw driver (PH000).
  5. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: paso 5, imagen 1 de 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: paso 5, imagen 2 de 2
    • Remove the black bundle battery connector from the motherboard using plastic opening tools.
  6. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: paso 6, imagen 1 de 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: paso 6, imagen 2 de 2
    • Use plastic opener tool to disconnect ZIF connectors as shown.
  7. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: paso 7, imagen 1 de 3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: paso 7, imagen 2 de 3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: paso 7, imagen 3 de 3
    • Remove speaker housing to expose ZIF connection underneath.
    • Then using metal tweezers disconnect the ZIF connector.
  8. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: paso 8, imagen 1 de 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: paso 8, imagen 2 de 2
    • Remove display and button connections from motherboard using metal tweezers.
  9. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: paso 9, imagen 1 de 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: paso 9, imagen 2 de 2
    • Remove unscrewed battery tray from main frame.
  10. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: paso 10, imagen 1 de 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: paso 10, imagen 2 de 2
    • Remove motherboard from hard frame.
    • When removing the motherboard make sure all screws that attach motherboard to hardframe are removed and to release plastic tab as shown in image.
  11. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: paso 11, imagen 1 de 2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: paso 11, imagen 2 de 2
    • Peel off button sensors off the side of the hard frame.
  12. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: paso 12, imagen 1 de 3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: paso 12, imagen 2 de 3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: paso 12, imagen 3 de 3
    • Apply slight pressure on camera to break adhesive to finish screen disassembly processes.
Conclusión
Nejad Harara
Miembro Desde 09/26/17
110 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S6-G3, Banghart Fall 2017 Miembro de Cal Poly, Team S6-G3, Banghart Fall 2017
CPSU-BANGHART-F17S6G3
5 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 1,684
