Saltar al contenido principal
Asus MeMO Pad 7 ME170C Speaker Replacement
Qué necesitas
  1. Asus MeMO Pad 7 ME170C Speaker Replacement, Speaker: paso 1, imagen 1 de 3 Asus MeMO Pad 7 ME170C Speaker Replacement, Speaker: paso 1, imagen 2 de 3 Asus MeMO Pad 7 ME170C Speaker Replacement, Speaker: paso 1, imagen 3 de 3
    • Before beginning to disassemble the device, power it off.
    • Make sure to be gentle with the device. Excessive force can result in a damaged screen.
    • Using the Jimmy tool, gently wedge it into the seam of the device at the side.
    • Pry the Jimmy tool gently all around the seam. Use up and down motions until the back panel is detached.
  2. Asus MeMO Pad 7 ME170C Speaker Replacement: paso 2, imagen 1 de 3 Asus MeMO Pad 7 ME170C Speaker Replacement: paso 2, imagen 2 de 3 Asus MeMO Pad 7 ME170C Speaker Replacement: paso 2, imagen 3 de 3
    • From the top of the tablet, locate the white cable connector.
    • It is inserted in a black port on the motherboard.
    • Use the blue plastic opening tool to push the white cable connector out of the port.
    • Push the cable in a sideways motion towards the top of the device.
  3. Asus MeMO Pad 7 ME170C Speaker Replacement: paso 3, imagen 1 de 2 Asus MeMO Pad 7 ME170C Speaker Replacement: paso 3, imagen 2 de 2
    • Use the Phillips #000 screwdriver to remove the seven screws.
    • There should be two silver and five black screws for a total of seven screws.
  4. Asus MeMO Pad 7 ME170C Speaker Replacement: paso 4, imagen 1 de 2 Asus MeMO Pad 7 ME170C Speaker Replacement: paso 4, imagen 2 de 2
    • Use the slender, metal spudger tool to gently lift up the edge of the speaker to remove the device.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 11
Ultimos 30 días: 13
Todo El Tiempo: 722
