Saltar al contenido principal
Asus MeMO Pad 7 ME170C Ribbon Cable Replacement
Qué necesitas
  1. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement, Ribbon Cable: paso 1, imagen 1 de 3 Asus MeMO Pad 7 ME170C Ribbon Cable Replacement, Ribbon Cable: paso 1, imagen 2 de 3 Asus MeMO Pad 7 ME170C Ribbon Cable Replacement, Ribbon Cable: paso 1, imagen 3 de 3
    • Before beginning to disassemble, power off the device.
    • Be gentle with the screen of the device. Excessive force can damage it.
    • Using the Jimmy tool, pry it into the seam of the device.
    • With the Jimmy tool, pry open the device through the seam.
  2. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: paso 2, imagen 1 de 3 Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: paso 2, imagen 2 de 3 Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: paso 2, imagen 3 de 3
    • Locate the black bundle cable connector attached to the battery.
    • Do not push down. Slide in a forward motion to avoid breaking any inner pieces.
    • Use the blue plastic opening tool to loosen the black bundle cable connector Loosen it in a back and forth motion towards the battery.
  3. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: paso 3, imagen 1 de 3 Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: paso 3, imagen 2 de 3 Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: paso 3, imagen 3 de 3
    • Use the plastic opening tool to loosen the battery by using the edges.
    • The battery should be laying freely in its port.
    • Lift the battery out of its port.
  4. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: paso 4, imagen 1 de 3 Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: paso 4, imagen 2 de 3 Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Use the wide nosed tweezers to remove the yellow tape that secures the bottom end of the ribbon cable. Gently lift the edge of the tape.
  5. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: paso 5, imagen 1 de 3 Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: paso 5, imagen 2 de 3 Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: paso 5, imagen 3 de 3
    • Using wide nosed tweezers, pinch the blue tab attached to the ribbon cable towards the top of the device that is inserted in the mother board.
    • Pull the ribbon cable firmly. However, do not rip it out.
    • In a lateral motion, pull the blue tab gently.
    • At the bottom of the device, use wide nosed tweezers to pinch the opposite blue tab of the ribbon cable.
  6. Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: paso 6, imagen 1 de 3 Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: paso 6, imagen 2 de 3 Asus MeMO Pad 7 ME170C Ribbon Cable Replacement: paso 6, imagen 3 de 3
    • The middle of the ribbon will be glued down to the device.
    • Heat the iOpener in the microwave for one minute.
    • After heating, vertically place the iOpener on top of the ribbon cable. Let it sit for one minute.
    • Remove the iOpener.
    • Use the wide nosed tweezers to pinch the ribbon cable from the middle. Pull it up firmly to detach. Be careful not to rip it off.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 11
Ultimos 30 días: 15
Todo El Tiempo: 1,125
