Saltar al contenido principal
Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement
Qué necesitas
  1. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Motherboard: paso 1, imagen 1 de 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Motherboard: paso 1, imagen 2 de 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Motherboard: paso 1, imagen 3 de 3
    • Power off the device before disassembly.
    • Be gentle; excessive force can result in a damaged or cracked screen.
    • Gently pry a Jimmy all around the seam of the device until the back panel detaches.
  2. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 2, imagen 1 de 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 2, imagen 2 de 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 2, imagen 3 de 3
    • Use an iFixit opening tool to gently push the black bundle cable connector in a forward motion until it loosens without pushing down on the bundle cable connector.
  3. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 3, imagen 1 de 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 3, imagen 2 de 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 3, imagen 3 de 3
    • Use the plastic opening tool to pry around the edges of the battery.
    • The battery should be laying freely in its port.
    • Lift the battery out of its port.
  4. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 4, imagen 1 de 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 4, imagen 2 de 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 4, imagen 3 de 3
    • Use a plastic opening tool to slide the white cable connector completely out of the port.
  5. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 5, imagen 1 de 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 5, imagen 2 de 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Flip up the beige clip to loosen the cable.
    • Use the wide nosed tweezers to pinch the blue tab attached to the ribbon cable.
    • Pull the blue tab gently in a lateral motion until it is completely out of its port.
  6. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 6, imagen 1 de 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 6, imagen 2 de 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 6, imagen 3 de 3
    • Use the wide nosed tweezers to gently pull out the orange ribbon inserted in the port on the motherboard.
  7. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 7, imagen 1 de 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 7, imagen 2 de 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 7, imagen 3 de 3
    • Use a plastic opening tool to push the white cable connector out of its port in a side to side motion.
  8. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 8, imagen 1 de 2 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 8, imagen 2 de 2
    • Use the Phillips #000 screwdriver to unscrew the seven screws.
    • There should be two silver and five black screws.
  9. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 9, imagen 1 de 2 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 9, imagen 2 de 2
    • Once the screws are removed, the speaker component will be loosely laying in the track.
    • Use the metal spudger tool to remove the speaker by gently lifting the edge of it.
  10. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 10, imagen 1 de 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 10, imagen 2 de 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 10, imagen 3 de 3
    • Remove the silver tape on one corner with the needle nosed tweezers, and remove the tape from the motherboard.
  11. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 11, imagen 1 de 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 11, imagen 2 de 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 11, imagen 3 de 3
    • Use the needle nosed tweezers to gently pull both of the orange ribbon cables out of their ports.
  12. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 12, imagen 1 de 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 12, imagen 2 de 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 12, imagen 3 de 3
    • Use the Phillips #000 screwdriver to unscrew all five screws.
  13. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 13, imagen 1 de 2 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: paso 13, imagen 2 de 2
    • To uninstall the motherboard, use the metal spudger tool to lift it out of the device.
  14. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Rear Facing Camera: paso 14, imagen 1 de 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Rear Facing Camera: paso 14, imagen 2 de 3 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Rear Facing Camera: paso 14, imagen 3 de 3
    • Gently remove grey tape that is holding down connector for camera using the tweezers.
    • When tape is removed, use the plastic prying tool to gently unlock connector between camera wiring and motherboard. The connector lock rotates upward away from motherboard to release.
    • Carefully remove camera from motherboard using tweezers by pulling directly upward. Camera should release easily without much resistance.
Conclusión
Thomas Brooks
Miembro Desde 03/04/17
301 Reputación
3 Guías creadas
Equipo
IUPUI, Team S3-G3, Wilson Spring 2017 Miembro de IUPUI, Team S3-G3, Wilson Spring 2017
IUPUI-WILSON-S17S3G3
Miembros de 5
6 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 155
