Saltar al contenido principal
Asus MeMO Pad 7 ME170C Microphone Replacement
Qué necesitas
  1. Asus MeMO Pad 7 ME170C  Microphone  Replacement, Microphone: paso 1, imagen 1 de 3 Asus MeMO Pad 7 ME170C  Microphone  Replacement, Microphone: paso 1, imagen 2 de 3 Asus MeMO Pad 7 ME170C  Microphone  Replacement, Microphone: paso 1, imagen 3 de 3
    • Before beginning to dissemble, power off the device.
    • Excessive force can result in damaged or cracked screen. Be Gentle.
    • Using the Jimmy tool, gently wedge it into the seam of the device.
    • Gently pry the Jimmy tool all around the seam until the back panel is detached.
  2. Asus MeMO Pad 7 ME170C  Microphone  Replacement: paso 2, imagen 1 de 3 Asus MeMO Pad 7 ME170C  Microphone  Replacement: paso 2, imagen 2 de 3 Asus MeMO Pad 7 ME170C  Microphone  Replacement: paso 2, imagen 3 de 3
    • Inserted in a black port on the motherboard, locate the white cable connector on the left side of the tablet.
    • In a side to side motion, using the smallest opening tool, slide the white cable box completely out of the port towards the bottom of the device.
  3. Asus MeMO Pad 7 ME170C  Microphone  Replacement: paso 3, imagen 1 de 2 Asus MeMO Pad 7 ME170C  Microphone  Replacement: paso 3, imagen 2 de 2
    • Pull the wire out of its tracking panel gently.
    • Note: This wire should be fairly easy to pull out of the panel.
  4. Asus MeMO Pad 7 ME170C  Microphone  Replacement: paso 4, imagen 1 de 3 Asus MeMO Pad 7 ME170C  Microphone  Replacement: paso 4, imagen 2 de 3 Asus MeMO Pad 7 ME170C  Microphone  Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Note: The end of the wire is attached to a small taped black box.
    • Using wide nosed tweezers, lift up the tape and remove from black box.
    • Note: Black box will loosen up once the tape is removed.
    • Remove the component completely from the device.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 1,026
