Saltar al contenido principal
Asus MeMO Pad 7 ME170C Battery Replacement
Qué necesitas
  1. Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: paso 1, imagen 1 de 3 Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: paso 1, imagen 2 de 3 Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Before beginning to disassemble, Power off the device.
    • Excessive force can result in damaged or cracked screen. Be Gentle.
    • Gently wedge a Jimmy into the seam of the device.
    • Gently pry the Jimmy all around the seam until the back panel is detached.
  2. Asus MeMO Pad 7 ME170C  Battery Replacement: paso 2, imagen 1 de 3 Asus MeMO Pad 7 ME170C  Battery Replacement: paso 2, imagen 2 de 3 Asus MeMO Pad 7 ME170C  Battery Replacement: paso 2, imagen 3 de 3
    • Locate the black bundle cable connector attached to the battery of the phone.
    • Do not push down. Slide in a forward motion to avoid breaking any inner pieces.
    • Using a plastic opening tool, gently slide the black bundle cable connector towards the battery in a back and forth motion until loosened and it slides out of connection port.
  3. Asus MeMO Pad 7 ME170C  Battery Replacement: paso 3, imagen 1 de 3 Asus MeMO Pad 7 ME170C  Battery Replacement: paso 3, imagen 2 de 3 Asus MeMO Pad 7 ME170C  Battery Replacement: paso 3, imagen 3 de 3
    • Using a plastic opening tool, pry out the batteries to loosen them out.
    • The battery will be pried out of its port.
    • Lift the battery out of its port
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 11
Ultimos 30 días: 15
Todo El Tiempo: 3,193
