Introducción
When the RAM is replaced, you will have the ability to easily access frequently used files, boost the speed of your laptop and eliminate error messages. Before you begin, you must ensure that the device is completely powered off and the battery is removed.
Qué necesitas
Paso 1 Battery
Aviso: el paso 1 proviene de una guía que está marcada como "En progreso".
Flip the device over to its back cover.
Use the switches to release the battery from its adapter.
To access the compartment that holds the RAM, flip the laptop so the bottom cover is facing upward and the battery compartment is facing away from you.
2 personas más completaron esta guía.
