Saltar al contenido principal
Asus K55VD DVD Player Replacement
Qué necesitas
  1. Aviso: el paso 1 proviene de una guía que está marcada como "En progreso".
    • Power off the device completely
    • Flip the device over to its back cover.
    • Use the switches to release the battery from its adapter.
  2. Asus K55VD DVD Player Replacement, Hard Drive: paso 2, imagen 1 de 2 Asus K55VD DVD Player Replacement, Hard Drive: paso 2, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the two 1.5 mm screws in the smaller portion of the bottom cover.
    • After removing the screws, remove the smaller cover.
  3. Asus K55VD DVD Player Replacement: paso 3, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the 1.5 mm screws that hold down the hard drive.
  4. Asus K55VD DVD Player Replacement: paso 4, imagen 1 de 2 Asus K55VD DVD Player Replacement: paso 4, imagen 2 de 2
    • Remove the hard drive from the slot.
    • Remove the hard drive from its shell.
  5. Asus K55VD DVD Player Replacement, Optical Disk Drive: paso 5, imagen 1 de 1
    • Using the the Philips #0 Screwdriver remove highlighted screws.
  6. Asus K55VD DVD Player Replacement: paso 6, imagen 1 de 1
    • Lift plastic cover with tweezers.
    • Remove screw.
  7. Asus K55VD DVD Player Replacement: paso 7, imagen 1 de 1
    • Lift keyboard panel with plastic pry tool to remove.
  8. Asus K55VD DVD Player Replacement: paso 8, imagen 1 de 2 Asus K55VD DVD Player Replacement: paso 8, imagen 2 de 2
    • Unhook all ribbons to remove keyboard panel completely.
  9. Asus K55VD DVD Player Replacement: paso 9, imagen 1 de 2 Asus K55VD DVD Player Replacement: paso 9, imagen 2 de 2
    • Slide the DVD Player outward.
Conclusión
Una persona más ha completado esta guía.
Un comentario
LOL if you want to get out drive, open dvd drive, turn laptop off, remove screw cover, unscrew, pull the drive out, done :D This is stupidly overcomplicated and unnecessary.
Luke Malatinsky - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 1,155
