Introducción
If your screen begins to flicker, is broken, or cracked you can use this guide to remove and replace the screen in order to look as good as new.
  1. Flip the laptop over, such that the bottom of the laptop is facing upwards.
    • Flip the laptop over, such that the bottom of the laptop is facing upwards.
    • Ensure that the laptop is powered off prior to following this guide.
  2. Pull the latch to the right of the battery to the right. Pull the latch to the right of the battery to the right.
    • Pull the latch to the right of the battery to the right.
  3. Pull the latch to the left of the battery to the left. Hold the latch open with a finger to prevent it from closing. Pull the latch to the left of the battery to the left. Hold the latch open with a finger to prevent it from closing.
    • Pull the latch to the left of the battery to the left. Hold the latch open with a finger to prevent it from closing.
  4. While holding the second latch from the previous step, use another hand to reach underneath the battery. Pull the battery upwards and away from the laptop to remove it.
    • While holding the second latch from the previous step, use another hand to reach underneath the battery.
    • Pull the battery upwards and away from the laptop to remove it.
  5. Insert a card between the outer plate cover and the back plate.
    • Insert a card between the outer plate cover and the back plate.
    • There may be some clips that break.
  6. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  7. Using the card that has been inserted in the top of the screen follow the edge of the screen all the way down to each corner touching the keyboard. Some of the clips may break. If the cover is not being held by just the bottom, go around the screen again to ensure all of the clips have been popped.
    • Using the card that has been inserted in the top of the screen follow the edge of the screen all the way down to each corner touching the keyboard.
    • Some of the clips may break.
    • If the cover is not being held by just the bottom, go around the screen again to ensure all of the clips have been popped.
  8. Remove the plugs at the bottom corners to expose the screws beneath. Remove the plugs at the bottom corners to expose the screws beneath. Remove the plugs at the bottom corners to expose the screws beneath.
    • Remove the plugs at the bottom corners to expose the screws beneath.
  9. Using a JIS #00 screwdriver, remove the two 5 mm screws that were exposed by the bumpers being removed. Using a JIS #00 screwdriver, remove the two 5 mm screws that were exposed by the bumpers being removed.
    • Using a JIS #00 screwdriver, remove the two 5 mm screws that were exposed by the bumpers being removed.
  10. Using the card to loosen the remaining clasps inside the screen cover, remove the cover from the back plate and screen. If the cover does not come off of the screen and back plate easily, the cover may be stuck to the hinge. (This is usually due to dirt or grime) If the cover does not come off of the screen and back plate easily, the cover may be stuck to the hinge. (This is usually due to dirt or grime)
    • Using the card to loosen the remaining clasps inside the screen cover, remove the cover from the back plate and screen.
    • If the cover does not come off of the screen and back plate easily, the cover may be stuck to the hinge. (This is usually due to dirt or grime)
  11. Using a JIS #00 screwdriver, remove the six 5 mm screws from the back plate to screen connections in each of the 4 corners of the screen. Using a JIS #00 screwdriver, remove the six 5 mm screws from the back plate to screen connections in each of the 4 corners of the screen. Using a JIS #00 screwdriver, remove the six 5 mm screws from the back plate to screen connections in each of the 4 corners of the screen.
    • Using a JIS #00 screwdriver, remove the six 5 mm screws from the back plate to screen connections in each of the 4 corners of the screen.
  12. Remove the plastic covering the connections on the backside of the screen. Make sure back plate is being held so there is no strain occurring on the still connected cables.
    • Remove the plastic covering the connections on the backside of the screen.
    • Make sure back plate is being held so there is no strain occurring on the still connected cables.
  13. Pull up on the tape holding down the ribbon connector. Using the brown colored part of the cable pull the cable out of the connection point The connection point is delicate, try to pull straight back and away from the connection point.
    • Pull up on the tape holding down the ribbon connector.
    • Using the brown colored part of the cable pull the cable out of the connection point
    • The connection point is delicate, try to pull straight back and away from the connection point.
  14. Using a JIS #00 screwdriver, unscrew the six 2.5 mm screws while holding the bracket to the screen on the sides. The screen should be easily removed when all of the screws are taken out. The screen should be easily removed when all of the screws are taken out.
    • Using a JIS #00 screwdriver, unscrew the six 2.5 mm screws while holding the bracket to the screen on the sides.
    • The screen should be easily removed when all of the screws are taken out.
Conclusión
Una persona más ha completado esta guía.
Jarrett Wilson
Miembro Desde 05/11/18
243 Reputación
1 Guía escrita
Equipo
IUPUI, Team S2-G1, Baechle Fall 2018 Miembro de IUPUI, Team S2-G1, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G1
4 Miembros
5 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 4
Todo El Tiempo: 68
