Saltar al contenido principal
Asus K55N-DS81 Hard Drive Replacement
Qué necesitas
  1. Asus K55N-DS81 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop over, such that the bottom of the laptop is facing upwards.
    • Ensure that the laptop is powered off prior to following this guide.
  2. Asus K55N-DS81 Hard Drive Replacement: paso 2, imagen 1 de 2 Asus K55N-DS81 Hard Drive Replacement: paso 2, imagen 2 de 2
    • Pull the latch to the right of the battery to the right.
  3. Asus K55N-DS81 Hard Drive Replacement: paso 3, imagen 1 de 2 Asus K55N-DS81 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Pull the latch to the left of the battery to the left. Hold the latch open with a finger to prevent it from closing.
  4. Asus K55N-DS81 Hard Drive Replacement: paso 4, imagen 1 de 2 Asus K55N-DS81 Hard Drive Replacement: paso 4, imagen 2 de 2
    • While holding the second latch from the previous step, use another hand to reach underneath the battery.
    • Pull the battery upwards and away from the laptop to remove it.
  5. Asus K55N-DS81 Hard Drive Replacement, Rear Panel: paso 5, imagen 1 de 2 Asus K55N-DS81 Hard Drive Replacement, Rear Panel: paso 5, imagen 2 de 2
    • Using a JIS #00 screwdriver, unscrew the two 5 mm screws on either side of the laptop panel.
  6. Asus K55N-DS81 Hard Drive Replacement: paso 6, imagen 1 de 3 Asus K55N-DS81 Hard Drive Replacement: paso 6, imagen 2 de 3 Asus K55N-DS81 Hard Drive Replacement: paso 6, imagen 3 de 3
    • Remove the panel by pushing away from the laptop until the panel is free of the laptop.
    • Lift to remove the panel.
  7. Asus K55N-DS81 Hard Drive Replacement, Hard Drive: paso 7, imagen 1 de 1
    • Using a JIS #00 screwdriver, unscrew the four 5 mm screws fastening the hard drive enclosure to the laptop.
  8. Asus K55N-DS81 Hard Drive Replacement: paso 8, imagen 1 de 3 Asus K55N-DS81 Hard Drive Replacement: paso 8, imagen 2 de 3 Asus K55N-DS81 Hard Drive Replacement: paso 8, imagen 3 de 3
    • Grab the plastic tab located on the hard drive enclosure.
    • Pull the tab towards yourself, the hard drive will slide towards you as it disconnects from the motherboard.
    • Lift the enclosure by the tab to remove the enclosure from the laptop.
  9. Asus K55N-DS81 Hard Drive Replacement: paso 9, imagen 1 de 2 Asus K55N-DS81 Hard Drive Replacement: paso 9, imagen 2 de 2
    • Using a JIS #00 screwdriver, unscrew the four 3 mm screws securing the hard drive to the enclosure.
    • Do not forget to flip the enclosure over and unscrew the screws on the other side.
  10. Asus K55N-DS81 Hard Drive Replacement: paso 10, imagen 1 de 2 Asus K55N-DS81 Hard Drive Replacement: paso 10, imagen 2 de 2
    • Grab the hard drive and pull it away from the enclosure to remove it.
Conclusión
Una persona más ha completado esta guía.
Elliott Beckner
Miembro Desde 11/05/18
543 Reputación
4 Guías creadas
Equipo
IUPUI, Team S2-G1, Baechle Fall 2018 Miembro de IUPUI, Team S2-G1, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 433
