Saltar al contenido principal
Asus K55N-DS81 Battery Replacement
  1. Asus K55N-DS81 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop over, such that the bottom of the laptop is facing upwards.
    • Ensure that the laptop is powered off prior to following this guide.
  2. Asus K55N-DS81 Battery Replacement: paso 2, imagen 1 de 2 Asus K55N-DS81 Battery Replacement: paso 2, imagen 2 de 2
    • Pull the latch to the right of the battery to the right.
  3. Asus K55N-DS81 Battery Replacement: paso 3, imagen 1 de 2 Asus K55N-DS81 Battery Replacement: paso 3, imagen 2 de 2
    • Pull the latch to the left of the battery to the left. Hold the latch open with a finger to prevent it from closing.
  4. Asus K55N-DS81 Battery Replacement: paso 4, imagen 1 de 2 Asus K55N-DS81 Battery Replacement: paso 4, imagen 2 de 2
    • While holding the second latch from the previous step, use another hand to reach underneath the battery.
    • Pull the battery upwards and away from the laptop to remove it.
Conclusión
Una persona más ha completado esta guía.
Elliott Beckner
Miembro Desde 11/05/18
543 Reputación
4 Guías creadas
Equipo
IUPUI, Team S2-G1, Baechle Fall 2018 Miembro de IUPUI, Team S2-G1, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 259
