Saltar al contenido principal
Asus K53E-BBR3 Keyboard Replacement
Qué necesitas
  1. Asus K53E-BBR3 Keyboard Replacement, Battery: paso 1, imagen 1 de 3 Asus K53E-BBR3 Keyboard Replacement, Battery: paso 1, imagen 2 de 3 Asus K53E-BBR3 Keyboard Replacement, Battery: paso 1, imagen 3 de 3
    • Place your laptop face down in front of you.
    • Slide the button in the top right corner to the right so that the orange marker is showing.
    • Press the spring loaded latch to release the battery from the computer.
  2. Asus K53E-BBR3 Keyboard Replacement, Keyboard: paso 2, imagen 1 de 3 Asus K53E-BBR3 Keyboard Replacement, Keyboard: paso 2, imagen 2 de 3 Asus K53E-BBR3 Keyboard Replacement, Keyboard: paso 2, imagen 3 de 3
    • There is a ribbon connector underneath the keyboard. When lifting up the keyboard be gentle and carefully it up.
    • Insert the spudger into the indent near the "ESC" key.
    • Firmly wiggle the spudger across the keyboard in between the space until you can remove the keyboard.
  3. Asus K53E-BBR3 Keyboard Replacement: paso 3, imagen 1 de 1
    • Gently pull the ribbon cable to the right and out of its port.
Conclusión
Liza Sousa
Miembro Desde 10/17/16
355 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 1-1, Catania Fall 2016 Miembro de UMass Dartmouth, Team 1-1, Catania Fall 2016
UMASSD-CATANIA-F16S1G1
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 795
