Saltar al contenido principal
Asus K53E-BBR3 Hard Drive Replacement
Qué necesitas
  1. Asus K53E-BBR3 Hard Drive Replacement, Battery: paso 1, imagen 1 de 3 Asus K53E-BBR3 Hard Drive Replacement, Battery: paso 1, imagen 2 de 3 Asus K53E-BBR3 Hard Drive Replacement, Battery: paso 1, imagen 3 de 3
    • Place your laptop face down in front of you.
    • Slide the button in the top right corner to the right so that the orange marker is showing.
    • Press the spring loaded latch to release the battery from the computer.
  2. Asus K53E-BBR3 Hard Drive Replacement, Back Panel: paso 2, imagen 1 de 1
    • Unscrew two 5mm Phillips #1 screws.
  3. Asus K53E-BBR3 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Pull down and lift up on the back panel to remove it.
  4. Asus K53E-BBR3 Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 3 Asus K53E-BBR3 Hard Drive Replacement, Hard Drive: paso 4, imagen 2 de 3 Asus K53E-BBR3 Hard Drive Replacement, Hard Drive: paso 4, imagen 3 de 3
    • Unscrew the four 5mm Phillips #1 screws.
    • Lift the hard drive out of the computer.
  5. Asus K53E-BBR3 Hard Drive Replacement: paso 5, imagen 1 de 2 Asus K53E-BBR3 Hard Drive Replacement: paso 5, imagen 2 de 2
    • Unscrew the screws on the hard drive case.
    • Two 3mm Phillips #1 screws are located on one edge of the case.
    • The last two 3mm #1 Phillips screws are located on the opposite side of the case.
    • After you unscrew all four screws, the metal cage will fall off, leaving you with the hard drive.
Conclusión
Jacob O'Donnell
Miembro Desde 10/17/16
323 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 1-1, Catania Fall 2016 Miembro de UMass Dartmouth, Team 1-1, Catania Fall 2016
UMASSD-CATANIA-F16S1G1
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 1,783
