Saltar al contenido principal
Asus K50IJ Fan Replacement
Qué necesitas
  1. Asus K50IJ Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the tab over to unlock the battery cover located on the bottom-left corner of the laptop.
  2. Asus K50IJ Fan Replacement: paso 2, imagen 1 de 3 Asus K50IJ Fan Replacement: paso 2, imagen 2 de 3 Asus K50IJ Fan Replacement: paso 2, imagen 3 de 3
    • Lift the exposed lip and remove the battery cover.
  3. Asus K50IJ Fan Replacement: paso 3, imagen 1 de 3 Asus K50IJ Fan Replacement: paso 3, imagen 2 de 3 Asus K50IJ Fan Replacement: paso 3, imagen 3 de 3
    • Press the tabs on the battery and lift them. The battery should come out easily.
  4. Asus K50IJ Fan Replacement, Fan: paso 4, imagen 1 de 3 Asus K50IJ Fan Replacement, Fan: paso 4, imagen 2 de 3 Asus K50IJ Fan Replacement, Fan: paso 4, imagen 3 de 3
    • Using the PH1 screwdriver, remove the four 4 .75 mm screws that are located on the vent panel.
  5. Asus K50IJ Fan Replacement: paso 5, imagen 1 de 1
    • Remove the one .5 mm screw located in the top right corner of the battery compartment.
  6. Asus K50IJ Fan Replacement: paso 6, imagen 1 de 2 Asus K50IJ Fan Replacement: paso 6, imagen 2 de 2
    • Remove the bottom panel by sliding it toward the hinges and lifting the back panel up.
  7. Asus K50IJ Fan Replacement: paso 7, imagen 1 de 1
    • Unplug the wire cable attached to the fan by pulling it out .
  8. Asus K50IJ Fan Replacement: paso 8, imagen 1 de 2 Asus K50IJ Fan Replacement: paso 8, imagen 2 de 2
    • Using the PH1 screwdriver, remove the 3 .75mm screws labeled as 1, 2, and 3 on the fan. NOTE these screws have the labels "1", "2", and "3" next to them.
    • Lift the fan up with your fingers.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 15
Todo El Tiempo: 874
