Saltar al contenido principal
Asus GL551JW-AH71 Hard Drive Replacement
Qué necesitas
  1. Asus GL551JW-AH71 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Close the device and lay it upside down.
    • Unplug the device and make sure the device is powered off before removing the battery.
  2. Asus GL551JW-AH71 Hard Drive Replacement: paso 2, imagen 1 de 2 Asus GL551JW-AH71 Hard Drive Replacement: paso 2, imagen 2 de 2
    • Move the battery eject button to the right. The battery will be ejected.
  3. Asus GL551JW-AH71 Hard Drive Replacement: paso 3, imagen 1 de 2 Asus GL551JW-AH71 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Grab the battery and remove it from the device.
  4. Asus GL551JW-AH71 Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 2 Asus GL551JW-AH71 Hard Drive Replacement, Hard Drive: paso 4, imagen 2 de 2
    • Use a Phillips #000 screwdriver to remove the two 16 mm screws on the access panel.
  5. Asus GL551JW-AH71 Hard Drive Replacement: paso 5, imagen 1 de 1
    • Remove the access panel by lifting it up.
  6. Asus GL551JW-AH71 Hard Drive Replacement: paso 6, imagen 1 de 2 Asus GL551JW-AH71 Hard Drive Replacement: paso 6, imagen 2 de 2
    • Using the Phillips #000 screwdriver, remove the four screws holding the hard drive in place.
    • The pictures in this step do not contain a a hard drive. The location where the hard drive would be located is indicated by the orange rectangle.
  7. Asus GL551JW-AH71 Hard Drive Replacement: paso 7, imagen 1 de 1
    • Pull out hard drive.
Conclusión
2 personas más completaron esta guía.
William Kelley
Miembro Desde 03/20/19
1,035 Reputación
7 Guías creadas
Equipo
UMass Dartmouth, Team S8-G3, Bailey Spring 2019 Miembro de UMass Dartmouth, Team S8-G3, Bailey Spring 2019
UMASSD-BAILEY-S19S8G3
Miembros de 4
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 17
Todo El Tiempo: 340
