Saltar al contenido principal
Asus GL551JW-AH71 Fan Replacement
Qué necesitas
  1. Asus GL551JW-AH71 Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Close the device and lay it upside down.
    • Unplug the device and make sure the device is powered off before removing the battery.
  2. Asus GL551JW-AH71 Fan Replacement: paso 2, imagen 1 de 2 Asus GL551JW-AH71 Fan Replacement: paso 2, imagen 2 de 2
    • Move the battery eject button to the right. The battery will be ejected.
  3. Asus GL551JW-AH71 Fan Replacement: paso 3, imagen 1 de 2 Asus GL551JW-AH71 Fan Replacement: paso 3, imagen 2 de 2
    • Grab the battery and remove it from the device.
  4. Asus GL551JW-AH71 Fan Replacement, Optical Drive: paso 4, imagen 1 de 2 Asus GL551JW-AH71 Fan Replacement, Optical Drive: paso 4, imagen 2 de 2
    • Use a Phillips #000 screwdriver to remove the single 10mm optical drive screw.
  5. Asus GL551JW-AH71 Fan Replacement: paso 5, imagen 1 de 3 Asus GL551JW-AH71 Fan Replacement: paso 5, imagen 2 de 3 Asus GL551JW-AH71 Fan Replacement: paso 5, imagen 3 de 3
    • Insert a probe or paperclip gently into the eject pin hole to eject the optical drive tray.
  6. Asus GL551JW-AH71 Fan Replacement: paso 6, imagen 1 de 2 Asus GL551JW-AH71 Fan Replacement: paso 6, imagen 2 de 2
    • Gently grasp the optical drive assembly and slide it out of the laptop body.
  7. Asus GL551JW-AH71 Fan Replacement, Upper Assembly: paso 7, imagen 1 de 2 Asus GL551JW-AH71 Fan Replacement, Upper Assembly: paso 7, imagen 2 de 2
    • Using a Phillips #000 screwdriver, remove the two 11mm screws that hold the access panel in place.
  8. Asus GL551JW-AH71 Fan Replacement: paso 8, imagen 1 de 2 Asus GL551JW-AH71 Fan Replacement: paso 8, imagen 2 de 2
    • Carefully remove the access panel.
  9. Asus GL551JW-AH71 Fan Replacement: paso 9, imagen 1 de 2 Asus GL551JW-AH71 Fan Replacement: paso 9, imagen 2 de 2
    • Using a Phillips #000 screwdriver, remove the seven 11mm screws holding lower case to the laptop.
  10. Asus GL551JW-AH71 Fan Replacement: paso 10, imagen 1 de 1
    • Turn the laptop over and open the screen.
  11. Asus GL551JW-AH71 Fan Replacement: paso 11, imagen 1 de 3 Asus GL551JW-AH71 Fan Replacement: paso 11, imagen 2 de 3 Asus GL551JW-AH71 Fan Replacement: paso 11, imagen 3 de 3
    • Gently pry open the case with an iFixit opening tool.
    • The upper and lower assembly are connected with a display cable that will be removed in the next step. Do not pull the parts apart more than a few inches.
  12. Asus GL551JW-AH71 Fan Replacement: paso 12, imagen 1 de 3 Asus GL551JW-AH71 Fan Replacement: paso 12, imagen 2 de 3 Asus GL551JW-AH71 Fan Replacement: paso 12, imagen 3 de 3
    • Flip the laptop on the right side while still holding the upper and lower assemblies close together.
    • Unplug the display connector from the motherboard.
    • Remove the upper assembly.
  13. Asus GL551JW-AH71 Fan Replacement, Fan: paso 13, imagen 1 de 1
    • Place the separated motherboard keyboard side down.
  14. Asus GL551JW-AH71 Fan Replacement: paso 14, imagen 1 de 3 Asus GL551JW-AH71 Fan Replacement: paso 14, imagen 2 de 3 Asus GL551JW-AH71 Fan Replacement: paso 14, imagen 3 de 3
    • Unplug the fan connector cable from the motherboard with an iFixit opening tool.
  15. Asus GL551JW-AH71 Fan Replacement: paso 15, imagen 1 de 2 Asus GL551JW-AH71 Fan Replacement: paso 15, imagen 2 de 2
    • With a Phillips #00 screwdriver, remove the three 5mm screws that hold the fan in place.
  16. Asus GL551JW-AH71 Fan Replacement: paso 16, imagen 1 de 2 Asus GL551JW-AH71 Fan Replacement: paso 16, imagen 2 de 2
    • Gently remove the fan from the motherboard.
Conclusión
3 personas más completaron esta guía.
William Kelley
Miembro Desde 03/20/19
1,035 Reputación
7 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 22
Todo El Tiempo: 1,696
