Saltar al contenido principal
Asus G75VW-BHI7N07 USB Port Replacement
Qué necesitas
  1. Asus G75VW-BHI7N07 USB Port Replacement, USB Port: paso 1, imagen 1 de 3 Asus G75VW-BHI7N07 USB Port Replacement, USB Port: paso 1, imagen 2 de 3 Asus G75VW-BHI7N07 USB Port Replacement, USB Port: paso 1, imagen 3 de 3
    • Remove the screws around the back cover using a Phillips #1 screwdriver.
    • Take the back cover off using the opening tool.
  2. Asus G75VW-BHI7N07 USB Port Replacement: paso 2, imagen 1 de 3 Asus G75VW-BHI7N07 USB Port Replacement: paso 2, imagen 2 de 3 Asus G75VW-BHI7N07 USB Port Replacement: paso 2, imagen 3 de 3
    • Once you get rid of the back cover, spot all the screws marked ‘A’. There should be 10 in total.
    • Remove the battery using the slide release button.
    • This should expose 2 more ‘A’ marked screws.
    • Remove those using the same screwdriver.
  3. Asus G75VW-BHI7N07 USB Port Replacement: paso 3, imagen 1 de 2 Asus G75VW-BHI7N07 USB Port Replacement: paso 3, imagen 2 de 2
    • Using the opening tool, remove the disc drive cover.
    • Spot the 6 ‘B’ marked screws and remove them using the Phillips #1 screwdriver.
  4. Asus G75VW-BHI7N07 USB Port Replacement: paso 4, imagen 1 de 2 Asus G75VW-BHI7N07 USB Port Replacement: paso 4, imagen 2 de 2
    • Using the opening tool, pry open the keypad platform.
    • You will need to use your hands to get to the laptop’s internal systems by lifting the keypad platform.
  5. Asus G75VW-BHI7N07 USB Port Replacement: paso 5, imagen 1 de 3 Asus G75VW-BHI7N07 USB Port Replacement: paso 5, imagen 2 de 3 Asus G75VW-BHI7N07 USB Port Replacement: paso 5, imagen 3 de 3
    • Now that the fans are exposed, use the opening tool to unhook them at the 4 connecting points.
    • Detach the blue-colored electrical component using the opening tool.
    • Detach the white and black colored electrical component using the opening tool.
  6. Asus G75VW-BHI7N07 USB Port Replacement: paso 6, imagen 1 de 1
    • Using the Phillips #0 Screwdriver, remove the 5 screws around the edges of the motherboard.
    • Remove the 2 screws around the fan using the Phillips #0 Screwdriver which should be near the motherboard.
  7. Asus G75VW-BHI7N07 USB Port Replacement: paso 7, imagen 1 de 1
    • Carefully lift the motherboard up using the opening tool.
    • You should be able to see the USB port.
    • Now you will be able to desolder the faulty USB port.
    • Here is a link on desoldering Cómo soldar y desoldar conexiones
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 604
